07 silverado tire question.
Old Feb 18, 2008 | 9:25 AM
ChevyGuy31189's Avatar
Default 07 silverado tire question.
Whats the biggest tire I can put on a 2007 crew cab silverado 1500 without rubbing? and a 2' leveling kit
Old Feb 18, 2008 | 9:46 AM
Default RE: 07 silverado tire question.
anyone?
Old Feb 18, 2008 | 10:15 AM
Judge Z's Avatar
I´ll put 33x11.5R 18 ( 285 / 65 R 18 ) BFGAT KO on 18" Eagle rims
on (my incoming) ´08 2500 HD.
Also with 2" levelling kit.
Dealer said it should work properly. Don´t know, will see
Truck, tires and rims are on the way from States to me to Germany.
northey87's Avatar
Welcome to the forum!!! You got to give us some time to answer your questions. I don't the answer to your question, but someone here will, you just got to give them time.
Old Feb 21, 2008 | 2:52 PM
ax7221's Avatar
Im not completely 100% sure, but the suggested size for aftermarket tires range from 30-31, when I spoke with my brother, whos a tech at a dealership he said you'll reach the limit on speedo and odometer reading before fitment. Meaning, if you get a tire that BARELY clears everything, you will need to get an aftermarket programmer to bypass GM's max. tire size so the speedometer and odometer will work properly.
Old Feb 21, 2008 | 5:26 PM
Mcguinness's Avatar
without doing anything you can generally go up two sizes.
Old Feb 21, 2008 | 11:24 PM
cdusthockey's Avatar
buddy has an 07 and hes running 33 Dick Cepeks with no rubbing, but i dont know if id go any bigger
Old Feb 22, 2008 | 1:26 PM
ehhget's Avatar
I have an 01 w/ a 4" suspension lift - my tires are 33's and have good clearance but without the lift would be to big, not sure if the 2" leveling kit would get you there?
If you go to bf goodrich or goodyears site there are chart with diameters of all the tire sizes. I would put the leveling kit in then do some measuring, just keep in mind when you turn your wheels in the front- that is whereit will be tightest.
Old Feb 22, 2008 | 3:10 PM
Jeckel707's Avatar
Hey ChevyGuy31189, what brand of spacers did you get?I have been looking for a good brand and i was curious about the install, type of product and how well it is working for you? Is yours the new body style?
Old Feb 23, 2008 | 9:16 AM
Mcguinness's Avatar
Get a 6 inch suspension lift and you will have loads of options plus it will look great
tonymacias
2007 - 2013 (GMT900)
Aug 21, 2012 9:50 PM
lauraherota
Oct 19, 2011 9:04 AM
bamafutbal
Jul 29, 2010 9:24 PM
Top
Follow Us
