Last edit by: IB Advertising
- Chevrolet Silverado GMT800, GMT900, and K2XX Stereo Diagnostic
Guide to diagnose trouble and recommended solutions.
08 Silverado front door speakers are not working.
Well for a while the right side door speaker would cut in and out, then that speaker went out, and now the left side went out. I have no door chime, assuming that goes through the speaker. The two small speakers on the pillars work fine as well as the rears. I have done some research looking for the fix. I found that a lot of people have the same exact problem but I haven't found any answers. I don't really want an aftermarket stereo, but If I have to I will I guess. I know I could take it to the dealer but I always try to fix stuff myself first. Just wondering if the problem is in the head unit or the speakers? wire connections etc. Sounds like such a common problem that there must be a common solution. Thanks in advance to anyone who replies.
08silveradobrad,
It may be a connection problem. BCM is also a possibility. These are just suggestions, not a diagnosis. You may have to take the vehicle in for an inspection. A certified technician should be able to offer a more accurate diagnosis with a physical inspection.
Please keep us posted.
If you have additional questions, please feel free to contact me.
Louis
GM Customer Service
Louis
GM Customer Service
The factory speakers are not very good. They have paper cones and tend to have terrible sound when they get a few years on them. If you replace them do not get speakers with the paper cones. It is worth the money to get better ones.
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> 08silveradobrad,BCM stands for Body Control Module.
Louis
GM Customer Service
08silveradobrad,
Louis
GM Customer Service
Louis
GM Customer Service
ontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> f5fstop,I apologize; I read through the post quickly & was dealing with another post related to the radio not working at the same time. You are correct; the BCM could affect the radio, however, not just the two front speakers. I still suspect a connection issue.
Thank you for pointing out my error.
Louis
GM Customer Service
Just checking
Connections? Two separate radio circuits from the radio to two different speakers break at the same time? It could. Two speakers blow at the same time? They could. Radio blows two separate outputs at the same time? It could.
But from my experience with GM vehicles, I would get a known good speaker connect it to the wires in the door and see what happens. If you get sound, it's the speaker(s). No sound, it's a connection. In this case, the tweeters in the a-pillar are working so it is not the output from the radio, since most GM radios use one wire from the radio for the right front to a splice and from the splice two wires: one to the tweeter in the a-pillar and the other wire to the door speaker.
Also, my experience with GM vehicle is they do not use the best speakers in the world and in my H3 for example, I replaced all door speaker within the first two years. And like oldchevy says, do not use paper cone speakers. Get some decent poly speakers that can hold up to water/heat/dust and last for quite a few years.
