08 Silverado HVAC issue, won't blow hot air?
Old Sep 20, 2013 | 11:49 AM
khum's Avatar
Default 08 Silverado HVAC issue, won't blow hot air?
08 HVAC issue
I've looked through the posts and see many AC related issues but none that answer my question; I have a 2008 Silverado work truck, V6, auto. AC works, fan works, heat is intermittent depending on where it's set (defrost, feet, etc)and does not seem to get real hot, also the control for where the air blows (feet, defrost, etc.) seems to have a mind of its own.
We've checked fusses but cannot find a problem.
Any ideas, winter is coming!
Thanks
Old Sep 20, 2013 | 1:57 PM
GMtruckGuy's Avatar
1st off, is there enough radiator fluid in the radiator? If not enough it will not heat.
Old Sep 20, 2013 | 3:34 PM
khum's Avatar
Yep, radiator is is topped off with the proper amount of antifreeze.
Old Sep 20, 2013 | 4:24 PM
Official GM Rep
Originally Posted by khum
08 HVAC issue
Thanks
Hello khum,
Welcome to the Chevrolet Forum! We are happy to have you part of the community on here. I am sorry you are experiencing HVAC issues with your 2008 Silverado. We would like the opportunity to look into this for you. Please reach out to us via private message and include your contact information, VIN and current mileage. We look forward to hearing from you.
Sincerely,
Laura M.
Chevrolet Customer Care
Old Sep 20, 2013 | 6:22 PM
khum's Avatar
Not sure how to connect via private message???
Old Sep 20, 2013 | 6:40 PM
therewolf's Avatar
Hi khum,
Welcome to the Chevrolet forums.
How many owners has the truck had?
Have you verified that you have a thermostat
in the cooling system? Here down south, many
folks remove them completely.
Old Sep 20, 2013 | 9:20 PM
Official GM Rep
Hi khum,
You can send us a private message by clicking on our screen name and the drop down will have a "Send a private message" option.
Amber N.
Old Sep 21, 2013 | 8:55 AM
khum's Avatar
I am the second owner, I cannot confirm that it has a thermostat in place, I suppose that would be a good place to start, although the temp gauge never changes once it warms up no matter what the temp is outside (winter or summer).
Old Sep 22, 2013 | 8:34 AM
GMtruckGuy's Avatar
Usually as you start driving the heat will get to around 200 (195 degree thermostat)and then suddenly the temp drops to 170, which indicates the thermostat opened up. If it does not do this, then either there is not one or the one present is not functioning properly.
Old Sep 22, 2013 | 1:09 PM
therewolf's Avatar
If you are in a northern climate, IMHO, it would help level the playing
field, to go to the minimal DIY expense to change the thermostat and
gasket, also a new overflow cap. Dayco, Gates, or Stant brands are my
personal preference.
Sometimes the OE senders aren't that sensitive. So, you may or may
not see a deflection, as the thermostat opens and closes.
jrentas
Feb 2, 2021 1:35 PM
TahoeMatt
Oct 15, 2014 4:10 PM
philhill61
Apr 21, 2014 11:06 AM
Blaidd Drwg
Nov 19, 2013 3:49 PM
Surge709
Jun 19, 2012 12:44 PM
