1980 chevy scottsdale 20, need a little help guys
Old Sep 1, 2009 | 9:58 AM
  #21
Mike Sigmond's Avatar
ROTM Coordinator
I believe you can, worse case just you tube it.
Old Sep 1, 2009 | 5:08 PM
  #22
mudmaniac's Avatar
Ride of the Month
May 2009
I don't know if it's worth the trouble, I think we all know what a misfire and backfire sound like.
Old Sep 1, 2009 | 5:16 PM
  #23
ROTM Coordinator
Do you have a vacuum guage and a manual?, Id test you spark advance/EGR/ etc.. If you say you know your brake booster is robbing your vacuum or its going bad, thats a good indication of your problem. You can pinch the vacuum line to the brake booster to bypass it to see it it runs better but you wont have power brakes, just to diagnose it.
Old Sep 2, 2009 | 2:17 PM
  #24
89silverado283's Avatar
i took my truck to my friend "tracey hawker" he runs a local mech shop and he drag races a 69 camaro with around 1500 hp power and probly the same in torqe, and he did a few things to it and i told him what all i did and he said its my disturbuator, i guess the wieghts aint working right so im gonna buy one from him brand new from the summit magizine and it comes with a little better cap, rotor, and coil then stock for, "and this is with his discont" 104$ im gonna buy it... thanks for the help guys
Old Sep 2, 2009 | 3:56 PM
  #25
ROTM Coordinator
Cool ,glad you got it figured out.
Old Jun 9, 2011 | 10:40 PM
  #26
mrcleanmom's Avatar
have you checked your pick up coil in the distributor? Check your TDC (top dead center) and match that to your #1 plug on the distributor.. This will tell you if you timing chain is lined up or if you have jumped a tooth. These little checks cost u nothing. Also, make shure your egr valve is good.
Old Jul 8, 2011 | 11:04 PM
  #27
mrcleanmom's Avatar
A ground would be good.
Old Jul 8, 2011 | 11:05 PM
  #28
mrcleanmom's Avatar
As for me, in the midst of a complete rebuild intake up. Keep u posted.
Old Jul 9, 2011 | 8:54 PM
  #29
OLD WRENCH's Avatar
The screws you are referring to are only in use at idle. At road speed they are by passed. You didnt mention rotor,sometime they can burn thru and short to the shaft. I would also get the wires changed ASAP. Do not run 5 and 7 parralell to each other as they can induce current to each other causing a cross fire. Are the rockers all moving up and down the same distance? Could have wiped a cam lobe off. Set the timming at 4 degrees BTDC with the vac unhooked. Just some thoughts,hope they help.
2doorcaprice
Mar 31, 2015 5:42 PM
billd86
Nov 18, 2013 2:58 PM
mtbaird89
Jun 1, 2013 9:31 AM
The Chevro
Jan 27, 2012 7:39 AM
chrisdurer
Jan 29, 2011 12:39 PM
