1985 Chevy Pickup
Old Jul 8, 2009 | 1:15 PM
Cautiontape_1985's Avatar
Question 1985 Chevy Pickup
I just bought a 1985 Chevy pickup with a 5.0L V8 and it needs an automatic transmission. I don't know much about these things.. What should I be looking for?
Old Jul 8, 2009 | 8:40 PM
lukemoore646's Avatar
well, that depends if its 4x4, or an overdrive, give your VIN number to a chevy parts counter person, if they are nice they will tell you what it left the factory with
Old Dec 4, 2018 | 8:23 AM
SquareBodyOutcast's Avatar
I have a 1985 Scottsdale, 1/2 ton. I want to axle swap it with 3/4 ton axles, lift it 12 inches and run 40s (maybe bigger but 40s are my main goal right now). I am extremely curious how much work and money on top of that will I need to invest for the drive line work and everything else that comes with making that truck run, sit and look great on that lift?
Old Dec 4, 2018 | 11:10 AM
Check with your local shops and see how much they want to rebuild it.
Old Dec 4, 2018 | 11:21 AM
mikedyer123's Avatar
I can rebuild it for about 100 bucks
Old Dec 4, 2018 | 1:04 PM
you might want to see if you can just swap it for a v8
Old Dec 14, 2018 | 4:54 PM
chicagobearsjr's Avatar
Default Heater Core HELP!
This is my first post. I have a 1985 K10 Silverado with a GM 350 engine. I changed the heater core myself but after putting everything back together, the blower switch is not working. It doesn't work at any speed. Could I have unplugged something under the dash while putting the heater box back? I didn't notice anything unplugged when putting everything back. The core is heating up, no leaks, I just cant turn the blower on to defrost or heat the car. Anything will help! I noticed there are two cables hanging with a connector on the end. The wires are brown and orange. I can't see anywhere this connector would plug in
Old Dec 17, 2018 | 7:10 AM
chicagobearsjr
Um take it back apart and rewire it uh thats the only thing i can think to tell you without seeing a pic
Old Feb 5, 2019 | 4:30 PM
Default GM 350 popping and backfiring
I have a 1985 K10 with a GM 350 and just installed an edelbrock carb. The garage told me the quadrajet was bad so I bought my own Edelbrock and put it on myself. After a few times out, I noticed once I get up to 50mph or so the engine will start popping and won't accelerate. I would let off the gas and coast for a second and it would pick back up, but would do it again at that speed. It seemed to backfire, blowing the muffler, so I drove it back home. Is this a problem with my carb installation? I am sorry I am a beginner and I just cant afford another garage visit.
Old Feb 26, 2019 | 10:30 AM
dang bro
