1993 with no brake lights or cruise control
Old Aug 12, 2009 | 11:56 PM
brian7cees's Avatar
Default 1993 with no brake lights or cruise control
Hi everyone!!
We just took a 2000 mile family trip and had no problems, then this morning we had no brake lights or cruise control??? It all did work great on the trip. Also fyi we have never had emergency flashers.... I have checked the fuses under the dash and all are ok.... I replaced the turn signal relay and the relay beside it... There is NO fuse box under the hood, the reaason I checked is I had a 95 with no brakes and that fuse was blown and that did fix that truck!! No luck with this one as no fuse box underhood.... I also checked the switch at the brake pedal and have NO power to any of the leads..... Any idea's would be appriciated!!
Thank you,
Brian
Old Aug 13, 2009 | 12:02 AM
lukemoore646's Avatar
try running power to the main power lead on the switch, i dont know which one it is sorry, and see if everything works, if it does you have a broken wire, then it would almost be easier to run a new wire instead of tracing out the factory one
Old Aug 13, 2009 | 12:13 AM
brian7cees's Avatar
Yes I thought of that as well, I do have a chiltons that does not show either the brake swich or cruise control circuits so I would have no clue witch wire/wires to jump to?? Besides I really would like to keep it all original if I could and find and fix the problem... I have found that saves head aches down the road... But hey thanks for your thoughts!!
Also on another forum someone made mention of asking if cruise control worked when anothere was having brake light problems, but offered no solution... that tells me there is a solution to this issue??
Brian
Hectorson3
Sep 13, 2014 12:22 PM
pcwilcox
Oct 21, 2013 11:00 AM
liljoe66
Aug 5, 2011 12:44 PM
chevyridinghi
Jun 4, 2009 8:07 PM
kbridge234
Sep 4, 2008 10:03 AM
