1994 chevy 350 wont start
Old Jan 19, 2015 | 2:08 PM
chevykid1994's Avatar
Default 1994 chevy 350 wont start
Alright I need some help with my truck. I got it about 5 months ago as a project truck. Replaced engine and trans. Engine ran great before being pulled from parts truck. Got it in the other truck now and it wont start. Can spray starting fluid in tb and all it does is pop and backfire through tb. Need some help asap. Thanks in advance.
Old Jan 19, 2015 | 7:01 PM
burhead1's Avatar
Make sure the grounds around the thermostat housing are grounded. Make sure your crank sensor is connected. It sounds like the timing is out, you will have to crank to TDC and check under the distributor cap, make sure the rotor is close to number 1. Does not have to be dead on but close, when you do get it going you will need to do a crank relearn using a scanner.
Old Jan 20, 2015 | 12:39 PM
That was the exact problem. Got it running last night. But what do you mean by having to do a crank relearn?
Old Jan 20, 2015 | 10:44 PM
burhead1's Avatar
using a scanner it tells the computer the variation between your crank and cam, if not done can cause engine light to flash on hwy and poor fuel economy. Should be done any time cam, crank sensor, computer or engine is replaced.
streetterrorist
13
Apr 15, 2022 1:42 PM
Kylewebb95
Oct 4, 2014 1:20 AM
dnelly
May 6, 2014 1:48 PM
00chevyk2500
Jan 1, 2012 5:39 PM
dj alacran
May 24, 2011 12:05 PM
