1994 K1500 instrument cluster lens removal?
I had some body work done a few years back and when they cleaned my vehicle up afterwards they must have used a wet cleaner on the dash and it ran down the inside of the instrument cluster lens. I was wondering how the trip meter reset button comes off. I tried to turn it thinking it may unscrew but either its real tight or removes a different way, I don't want to break it if it does not unscrew. Thanks.
See if this gives you any direction.
Not your model, but might you some information to help you get started.
Also do a search on You Tube, They just might have the exact video.
Good luck.
Good luck.
![Smile](https://chevroletforum.com/forum/images/smilies/smile.gif)
On that model it looks like the button just slips through the glass, mine has a larger head on it so it needs to come off first maybe the head just slips on the shaft will have to do a little more searching, thanks
All I want to do is take the lens off and clean it, it has a few screws holding it on but the trip meter reset button that goes through it but has a bigger tip on it where you push it than the hole it passes through. I think it unscrews but want to be sure so I don't twist it off if it does not unscrew
I'll post how I get it off when I do...probably in a week or so...maybe on Christmas since I'm off that day.
I may do a test on a truck at the junk yard first...either way I'll need to get this off.
Hmmm...I'll be needing to remove this lens as well soon, as I'll be repairing my ODO and trip meter.
b1pig
June 1st, 2007 3:52 PM
biglg
February 23rd, 2007 4:25 AM
PowhatanPete
September 3rd, 2006 7:25 PM
