1994 K1500 instrument cluster lens removal?
Old Dec 1, 2012 | 5:41 PM
Nebraskadriver's Avatar
Default 1994 K1500 instrument cluster lens removal?
I had some body work done a few years back and when they cleaned my vehicle up afterwards they must have used a wet cleaner on the dash and it ran down the inside of the instrument cluster lens. I was wondering how the trip meter reset button comes off. I tried to turn it thinking it may unscrew but either its real tight or removes a different way, I don't want to break it if it does not unscrew. Thanks.
Old Dec 1, 2012 | 10:32 PM
skeeter5's Avatar
Default Button removal
See if this gives you any direction.
Not your model, but might you some information to help you get started.
Also do a search on You Tube, They just might have the exact video.
Good luck.
Old Dec 4, 2012 | 9:14 AM
On that model it looks like the button just slips through the glass, mine has a larger head on it so it needs to come off first maybe the head just slips on the shaft will have to do a little more searching, thanks
Old Dec 4, 2012 | 9:18 AM
Retcher's Avatar
I would not do that myself. If you have no idea how to get that fixed that better to wait for scheduled maintenance or at least visit specialist.
I would not touch that.
Old Dec 8, 2012 | 11:09 PM
All I want to do is take the lens off and clean it, it has a few screws holding it on but the trip meter reset button that goes through it but has a bigger tip on it where you push it than the hole it passes through. I think it unscrews but want to be sure so I don't twist it off if it does not unscrew
Old Dec 19, 2012 | 6:09 PM
HMAJNG's Avatar
Hmmm...I'll be needing to remove this lens as well soon, as I'll be repairing my ODO and trip meter.
I'll post how I get it off when I do...probably in a week or so...maybe on Christmas since I'm off that day.
I may do a test on a truck at the junk yard first...either way I'll need to get this off.
Old Dec 29, 2012 | 2:04 AM
Good idea, to test it in the junkyard. I did get a response from a guy who sells the new lens on e-bay, he says the rubber tip will just pull off of the shaft that is the reset button, after looking at it I think he is correct its just a rubber tip. I suppose one would probably want to hold the shaft with a needle nose pliers so as not to be pulling on the internals. I look forward to your junkyard test if you get it done. Should confirm what he says I hope. Thanks.
tekniq
34
Jul 4, 2022 1:26 PM
lostkauaiboy
Feb 27, 2013 10:39 PM
b1pig
Jun 1, 2007 3:52 PM
biglg
Feb 23, 2007 4:25 AM
PowhatanPete
Sep 3, 2006 7:25 PM
