1995 K Silverado ABS Trouble Code
Old Sep 5, 2010 | 4:45 PM
danhiman's Avatar
Default 1995 K Silverado ABS Trouble Code
I have a 1995 CK Silverado 5.7K, the abs light will go on then off, not consistently, does not go on when i turn the wheel. If it goes on i apply the brakes, and it goes off. I did the jump on the ALDL H to A and it gives the 13 code. My Chilton says 12 and 14 are normal, on line , I found that 13 and 14 are ecu failure codes, my brakes are strong.???????
Old Sep 5, 2010 | 5:56 PM
danhiman's Avatar
light turns on at 15 miles per hour and stays on, then turns off when below 16 miles per hour.
Old Sep 11, 2010 | 6:22 PM
danhiman's Avatar
So just in case any of you want to know. It was my brake pedal light switch. It also stops the cruise control. $10
Tony_B.
12
Jan 23, 2016 4:15 PM
incufilter
Mar 23, 2011 8:47 PM
dozer157
Sep 8, 2009 7:32 PM
jziggy5
Feb 18, 2009 4:03 PM
ingolenssen
Nov 22, 2007 11:14 AM
