1996 Chevy 1500, What is this rubber cap on my radiator?
Old Sep 20, 2011 | 8:10 AM
mattersnot's Avatar
Default 1996 Chevy 1500, What is this rubber cap on my radiator?
1996 Silverado, 5.7 liter, I think heavy-duty radiator. This truck has a small (3/4") rubber cap clamped over a nipple on the radiator a couple of inches below the radiator cap. It split yesterday and soaked me. I've looked on all sorts of parts diagrams, and its now shown. Anyone have a clue of what its called or a part number? Thanks!
Old Sep 20, 2011 | 9:15 AM
OLD WRENCH's Avatar
Check with a good radiator shop they might be able to help.
Old Sep 21, 2011 | 1:27 PM
mattersnot's Avatar
Default Red neck temporary fix
Thanks. Since the nearest shop is 25 miles away I came up with a temporary fix this morning . . . a short piece of 3/4" PEX plumbing pipe and a plug. I noticed the factory clamps were Cinch clamps like used on PEX, had a clamp tool and nothing to lose.
Old Sep 21, 2011 | 2:28 PM
kevinkpk's Avatar
Sounds to me like it is for the overflow. Is there a plastic tank near the radiator that isn't hooked to anything?
Old Sep 21, 2011 | 4:10 PM
OLD WRENCH's Avatar
This is a guess, but that rad might be a universal that has this fitting for vehicles that the heater dumps into the rad not the motor.
Old Sep 21, 2011 | 4:13 PM
kevinkpk's Avatar
The size (3/4") and location if it is 3/4" would certainly make sense. I was actually questioning the diameter.
Old Sep 22, 2011 | 5:30 PM
mattersnot's Avatar
Default More facts
It's not the overflow, but is directly below the overflow fitting. The actual size is slightly smaller than .67", since that's the ID of 3/4" PEX pipe. The Clinch Clamps were identical ones with what I use to plumb PEX piping. I suspect Old Wrench is correct - it was put there for some special application used by another vehicle. Next trip back to civilization I will take the rubber hose cap to a Chevy dealer and let them scratch their head. I'll still take my truck over my sister's CTS Cadillac any day. It cost her over $200 to have a front turn signal light replaced. Yips!
Old Sep 22, 2011 | 5:35 PM
kevinkpk's Avatar
Plug it back off
Old Jan 27, 2022 | 3:41 PM
Ducoti's Avatar
hi, got the same issue. I've been dealing with it for 20 years. That nipple is fir the heat return. Mine never had one so I've been buying the rubber cap like you mentioned and also made a similar fix. It sucks. Let me know if you find a permanent solution.
EricVanNostrand
Nov 1, 2014 4:25 PM
Chameleon
Dec 11, 2012 7:02 AM
JWR4
Mar 11, 2012 4:38 AM
BA002
Jun 20, 2008 11:13 AM
v6c2500
Feb 11, 2007 6:33 AM
