1996 z71 5.7 jumping on wot.
Attempted to burnout at a stop sign while it was raining on black top and it started jumping violently until I let out of the gas and it cleared up. pulled some codes for o2 sensors and egr valve so I cleaned the egr and its still the same. it has 164,xxx miles. whats the problem??
From your vague description of "jumping" not sure what you mean...engine or entire truck?
I would guess wheel hop because it ended when you let off the gas.If that is the case the codes pulled would be irrelevant.
Like stated your description is iffy.....post the codes and give more details.
That's why your not getting any responses...we can't read your mind.
Just trying to help.........shot in the dark....sticking butterfly in the Throttle body
bobehud
Sep 17, 2011 7:00 AM
