1997 chev 1500 5.7l
Hello to all!
I have a Chevrolet that is a no start. Had codes pulled on it and they are as follows:
P0101 Mass air flow circuit out of range
P0108 MAP or BARO pressure signal high
P0337 CKP sensor A signal low frequency
P0340 Camshaft position sensor problem
P1106 MAP sensor circuit intermittent high
There is fuel smell in crankcase. With ignition on you hear fuel pump cut on, relays click, cuts off fuel pump and the spyder back under intake has a constant buzz sound.
Any suggestions?
Thank you in advance.
Any suggestions?
bentwrench
Aug 25, 2011 5:52 PM
Spursky
Aug 14, 2011 4:08 PM
kimmers
Sep 21, 2010 2:08 PM
animul
Dec 12, 2007 12:36 PM
