1998 Chevy Silverado K1500 Z71 Issues
Old Jun 20, 2011 | 1:51 PM
  #11
dungholio's Avatar
Check the fuel pressure! If you have installed a new fuel filter and then the problem happened its cause the filter was so clogged that when the flow gets better it takes the pump out. seen it a million times
Old Jun 20, 2011 | 2:11 PM
  #12
basilkies's Avatar
Did you replace the fuel? Old fuel doesn't burn well. If you light an ounce of old fuel in a cap and an ounce of new fuel you will see a huge difference in flames.
Old Jul 18, 2011 | 9:40 PM
  #13
OleRedTruck's Avatar
Well if you are military and that's why you were overseas, Thank You!
Old Sep 12, 2011 | 10:29 AM
  #14
SteveLNew's Avatar
Had same problem with another Chevy truck and it turned out to be fuel pump.
Once I got it started there was enough vacume to pull in fuel. (at idle)
Old Sep 18, 2015 | 12:08 PM
  #15
BobbyD's Avatar
I have a 1998 Chevy truck that has been setting for a while .Starter was bad so i had it rebuilt, when i installed it and connected to battery it started cranking without the key in the truck!So i removed the starter and did a field test on it and worked perfectly!I also checked the wiring at the starter to make sure they weren't grounded out. Any Ideas?
Ally25
Mar 7, 2015 1:52 PM
ally24
Mar 7, 2015 1:21 PM
BrandonT79
Feb 24, 2015 7:24 PM
Morphsuit
Oct 8, 2013 6:06 AM
Xslashdashx
Jan 21, 2013 2:17 AM
