1998 Silverado Z71 5.7L smokes
Old Apr 6, 2012 | 10:37 AM
mikeymike's Avatar
Default 1998 Silverado Z71 5.7L smokes
Hello Fellas
I just bought me a used Z71 that has a 5.7L in it and I did not
notice that it smoked a little when I bought it. I am tring to figure out why it is smoking.
This is what I know about the truck.
It has the catalytic converter removed!
It has 254000 miles on it.
At the tip of the exhaust it does not appear to have any oil on it.
It does seem that the smoke is maybe from moisture as there is moisture at the tip of the exhaust.
when first starting it up after it has been sitting for a few hours it takes a few seconds to start.
I am wondering if this is something to be very concerned about or if it is maybe a bad head gasket where the antifreeze is leaking into the
cylinders or something like that.
Anyone have any ideas?
Thanks for any info you can provide.
Mike
Old Apr 6, 2012 | 11:28 AM
Do a compression check as the first step.
Old Apr 6, 2012 | 6:40 PM
Allan In NE's Avatar
Moisture at the tailpipe is totally normal.
Keep track of how much oil it using. Sounds like you might be about due for an engine.
Allan
Old Apr 6, 2012 | 9:44 PM
SweetEmotion's Avatar
worn piston rings
Old Apr 8, 2012 | 10:55 AM
mikeymike's Avatar
Thanks Guy's
Old Apr 8, 2012 | 4:02 PM
jgray152's Avatar
everyone is saying time for a new engine but no one knows what color this "smoke" is. if its blueish then its oil....white...give a sniff...if it smells sweet then its coolent....if neither then just moisture n dont worry bout it
Old Apr 9, 2012 | 6:48 AM
mikeymike's Avatar
It was a very light smoke and I drove it a lot this weekend and did not see it anymore. I'm hoping it is just moisture. Thanks jgray
maxxman04
Mar 1, 2017 9:54 PM
nrbukowski
Jul 22, 2011 9:22 PM
cva59
Nov 29, 2010 1:54 PM
Paul Seidman
Avalanche
Aug 18, 2010 3:33 PM
mryan_davis
Aug 29, 2009 11:40 AM
