1998 Z71 sputters when idling but runs fine
Old Jun 19, 2012 | 7:48 AM
jbthomas9584's Avatar
Cool 1998 Z71 sputters when idling but runs fine
My 98 Z71 runs fine and has no issues except it sputters while idling. Whether it's in park, nuetral, or if I am sitting at a redlight, it sputters and feels like it's about to die but then when i accelerate, i have no issues. Any suggestions? Thanks.
Old Jun 19, 2012 | 5:31 PM
shamrock246's Avatar
Any codes stored?
Old Jun 19, 2012 | 6:47 PM
Doug Roberts's Avatar
Throttle position sensor
Old Jun 19, 2012 | 7:14 PM
Mudd Mutt's Avatar
O2 sensor. Happened to me twice. Idles like crap and shook the truck. It took about a month for it the throw a code
Old Jun 20, 2012 | 8:35 AM
No codes stored. Checked twice.
There are 4 O2 sensors, do i just need to replace all of them?
I 'll have to do some research on the throttle position sensor, I don't know anything about it.
Just found out the spark plug wires got wet during clean up under the hood. Should i try replacing those first?
Old Jun 20, 2012 | 11:00 AM
I had something like that and it was a vacuum leak. Check all your vacuum hoses for loose connections and cracks.
Old Jun 20, 2012 | 4:19 PM
Mudd Mutt's Avatar
Just the two pre cat sensors would be the cause of it. It's probably running to lean but only enough to notice at low RPM's. If its the sensors you'll gradually lose power then sensors will throw a code
Old Jul 1, 2012 | 8:59 PM
Jeffdrummonds's Avatar
I just had this happen to me! As OldChevy posted above, it was a vacuum leak! Good luck!
Old Jul 2, 2012 | 10:19 AM
Default 1998 Z71 sputters when idling but runs fine
So i am not familliar with vaccum leaks. Is it something i can do myself?
What all is involved?
Old Jul 2, 2012 | 12:24 PM
kevinkpk's Avatar
Personally I use WD-40 and spray on intake matting surfaces, hose connections ect with it running. If it's sucking air, and you hit that with WD it will speed the rpm's up. You can use starting fluid spray. If your vacuum hoses are old/brittle replace them. Note there are (I belive) two different sizes.
Doug Wells 69
Aug 31, 2013 12:54 PM
Kurtnelson08
Oct 5, 2010 12:45 PM
Kurtnelson08
Oct 5, 2010 11:10 AM
survivaldog
Dec 7, 2008 4:44 PM
Beejay
Aug 31, 2008 7:35 PM
