1999 2500--Bad Waterpump? Waterpump Diagram?
Hi Folks-
Got a puddle of coolant under the 2500 in the driveway. Looks like the leak is coming from the water pump--it looks to be coming out of a weep hole on the underside of the pump. Coolant kept running out even after the truck was turned off. Sound to you folks like that's the culprit?
Anyone have a .pdf of the parts diagram for the waterpump or a .pdf of the service manual for this generation chevy?
Thanks for the help!
easy job then. get a good pump and a headstart early Saturday morning. Everything is like 13mm.
Get the pump, thermostat, coolant temp switch, serp. belt and check your fan clutch if equipped.
jsepps
Mar 29, 2014 5:44 PM
therewolf
Feb 18, 2009 11:46 AM
