1999 2500--Bad Waterpump? Waterpump Diagram?
Old Jan 4, 2011 | 3:54 PM
fourstop's Avatar
Default 1999 2500--Bad Waterpump? Waterpump Diagram?
Hi Folks-
Got a puddle of coolant under the 2500 in the driveway. Looks like the leak is coming from the water pump--it looks to be coming out of a weep hole on the underside of the pump. Coolant kept running out even after the truck was turned off. Sound to you folks like that's the culprit?
Anyone have a .pdf of the parts diagram for the waterpump or a .pdf of the service manual for this generation chevy?
Thanks for the help!
Old Jan 4, 2011 | 4:27 PM
RacerX's Avatar
What is it? 5.7? 5.3? 6.2? 7.4? Anyhow its an easy job, 3-4 hours of your life and it should be done.
Old Jan 4, 2011 | 6:31 PM
fourstop's Avatar
It's a 5.7
Old Jan 4, 2011 | 8:41 PM
RacerX's Avatar
easy job then. get a good pump and a headstart early Saturday morning. Everything is like 13mm.
Get the pump, thermostat, coolant temp switch, serp. belt and check your fan clutch if equipped.
jsepps
Mar 29, 2014 5:44 PM
hayseed
Dec 28, 2009 2:22 PM
therewolf
Feb 18, 2009 11:46 AM
SuperTexan
Oct 29, 2008 4:10 PM
GirlInTruck
Mar 12, 2008 10:57 PM
