1999 Silverado newer body style insturment cluster Problem
Old Jun 27, 2012 | 9:26 AM
poordude2151's Avatar
Default 1999 Silverado newer body style insturment cluster Problem
I seem to be having issues with my cluster in my 99' step side. I was driving down the road in cruise control and all of a sudden my battery light in message center came on, my cruise quit, my gas gauge quit, my temp gauge quit and my mileage/gear indication quit.
I have since tried to replace battery with a red top and checked all grounds. I even took off the paint where the ground goes to the front support to have a better connection.
I have messed around with the ignition switch by wiggling it around in off mode and start while engine is running and nothing happened.
Would this still be a grounding issue, ignition switch issue or cluster issue?
I really don't wanna start replacing stuff just guessing at it and it don't fix the issue.
What are your thoughts on this issue?
Thanks,
Billy
Old Jun 27, 2012 | 9:49 AM
country_09's Avatar
Get a buddies cluster and put it in, make sure it's a 99-02 though. If it doesn't do it with a different cluster in there then your old cluster needs to be replaced. Common gm problem.
Old Jun 27, 2012 | 10:14 AM
Sad thing is, I don't have any friends with this year truck.
Anyone in the Texas area have one I could borrow or buy?
Old Jun 27, 2012 | 10:26 AM
country_09's Avatar
Hmm what part of Texas?
Old Jun 27, 2012 | 10:29 AM
East Texas Part
Around Tyler, TX area
Old Jun 27, 2012 | 10:32 AM
Here she is
Old Jun 27, 2012 | 11:19 AM
I don't see that you checked the fuses. Start with that.
Old Jun 27, 2012 | 11:47 AM
I checked all fuses in the box under the hood. Are there anymore else where? All checked out.
Old Jun 27, 2012 | 11:55 AM
There is another fuse box in the dash on the drivers side.
Old Jun 27, 2012 | 12:18 PM
Under a black cover? I seen nothing but plugs?
