2000 Chevrolet Silverado
Old Jan 13, 2022 | 3:23 AM
Reggie779's Avatar
Default 2000 Chevrolet Silverado
My truck was running fine until I tried to crank it the following morning....turns over but won't crank
Old Jan 13, 2022 | 2:31 PM
That's not much information. Is the check engine light on? If it is, what is the code?
Old Jan 13, 2022 | 5:52 PM
Reggie779's Avatar
Default Engine stalled
I also noticed that my check engine light wasn't on so please somebody point me in the correct direction
Old Jan 14, 2022 | 7:57 AM
Check your fuel pressure. Try spraying some starter fluid or gas into the throttle body and see if it runs for a second or so. If it does then you have a fuel problem. Check for spark to see if it is an ignition problem.
Old Jan 14, 2022 | 6:17 PM
Welcome to the forum Reggie. I am moving your post to the Silverado section so you will get more views.
