2000 Chevy Z71 shakes when braking...
I have a 2000 Z71 4wd ext cab with 5.3L that shakes randomly when braking. It seems to be worse with a passenger. The whole entire truck will shake. Sometimes it will start to and then smooth out other times not at all. I have replaced both upper control arms, lower on left side, left and right hub assembly and rotors along with pads on front, idler arm, abs pump and mod and new tires. Any ideas would be greatly appreciated I'm almost $2000 in and at a loss. Thank you for your time.
No Sir, I don't feel anything in either, it doesn't pull to one side or the other. I have made stops with it shaking and let go of the steering wheel and it keeps straight and it doesn't start doing it until after I have made several stops, the more stops I make the more it shakes
Four wheel disc but I have had that thought and when I asked around no one thought rear warped rotors would cause that kind of shake. I will differently give it a shot and report back. Thank you...
I've warped a lot of rotors in my life. Several of them shook pretty hard - kind of like hitting a specific resonant frequency - at a particular combination of speed and pedal pressure.
trippymg
November 17th, 2016 8:00 PM
10ecvolsfan
January 9th, 2015 8:26 PM
eisenhauer01
37
March 15th, 2010 4:20 AM
jmckeage
November 10th, 2009 7:21 PM
live4perfection
May 6th, 2008 10:59 AM
