2000 Chevy Z71 shakes when braking...
Old Sep 9, 2015 | 12:33 PM
bobbygrn24's Avatar
Default 2000 Chevy Z71 shakes when braking...
I have a 2000 Z71 4wd ext cab with 5.3L that shakes randomly when braking. It seems to be worse with a passenger. The whole entire truck will shake. Sometimes it will start to and then smooth out other times not at all. I have replaced both upper control arms, lower on left side, left and right hub assembly and rotors along with pads on front, idler arm, abs pump and mod and new tires. Any ideas would be greatly appreciated I'm almost $2000 in and at a loss. Thank you for your time.
Old Sep 9, 2015 | 2:16 PM
does the shake transfer into the steering wheel or brake pedal?
Old Sep 9, 2015 | 5:42 PM
bobbygrn24's Avatar
No Sir, I don't feel anything in either, it doesn't pull to one side or the other. I have made stops with it shaking and let go of the steering wheel and it keeps straight and it doesn't start doing it until after I have made several stops, the more stops I make the more it shakes
Old Sep 9, 2015 | 10:22 PM
intheburbs's Avatar
Warped rear drum?
Old Sep 9, 2015 | 10:31 PM
bobbygrn24's Avatar
Four wheel disc but I have had that thought and when I asked around no one thought rear warped rotors would cause that kind of shake. I will differently give it a shot and report back. Thank you...
Old Sep 10, 2015 | 2:10 PM
intheburbs's Avatar
I've warped a lot of rotors in my life. Several of them shook pretty hard - kind of like hitting a specific resonant frequency - at a particular combination of speed and pedal pressure.
Old Sep 10, 2015 | 4:05 PM
bobbygrn24's Avatar
Gotcha, I appreciate the info and will get them turned this weekend.
Old Sep 26, 2015 | 5:04 PM
bobbygrn24's Avatar
Default Finally!!!!!!
Thank you for the help. I finally got a chance to replace the rear rotors and brakes and she stops as smooth as glass. Thanks again you rock.
trippymg
Nov 17, 2016 8:00 PM
10ecvolsfan
Jan 9, 2015 8:26 PM
eisenhauer01
37
Mar 15, 2010 4:20 AM
jmckeage
Nov 10, 2009 7:21 PM
live4perfection
May 6, 2008 10:59 AM
