2000 Silverado Issue
Old May 19, 2012 | 10:24 AM
Johnny_Coonass's Avatar
Default 2000 Silverado Issue
Pictured is the truck, she's been great but has a couple issues.
1st. - When cold, hard to start, if I turn the key on 4 times, then crank it, starts right up. If not requires some spinning. I am thinking fuel pump, or a cracked hose bleeding pressure in tank.
2nd. - ABS and Brake Light come on more often than not. No clue why, only code she is throwing is asking for a good tune up.
2000 Short bed Chevy Silverado
4.3
Automatic
4X4
<!-- / message -->
Old May 19, 2012 | 11:27 AM
I had those same 2 issues. The ABS and brake light still come on. I fixed the hard starting by putting a check valve in the fuel line between the filter and the tank.
Old May 20, 2012 | 3:57 PM
trebreklaw's Avatar
My abs light was caused by bad front wheel bearing assembly.
Old May 23, 2012 | 10:58 AM
johntaps's Avatar
Former Sponsor
The fuel pressure regulator can cause the prolonged crank
2000 Chevrolet Silverado 1500 Fuel Injection Pressure Regulator - Standard Motor Products, Delphi, AC Delco - TheAutoPartsShop - TheAutoPartsShop
Check the fuel pressure with a gauge to verify the pressure drops after a few hours. Then try the pressure on the line from the tank. That should point you in the right direction.
ABS issues are common and often are the sensors, which are part of the hub/bearing.
2000 Chevrolet Silverado 1500 Wheel Bearing And Hub Assembly - Part Master, Timken, National - TheAutoPartsShop - TheAutoPartsShop
milliron
May 25, 2015 4:41 AM
runchevyrun
Feb 12, 2014 2:24 PM
Stimpy911
Oct 12, 2011 2:40 AM
Rman67
Feb 15, 2011 7:35 PM
xhassismec
Mar 13, 2010 8:28 PM
