2000 Silverrado 2WD won't run above an idle
Old Oct 29, 2009 | 7:47 PM
quills's Avatar
Default 2000 Silverrado 2WD won't run above an idle
I'm hoping someone can help with this. My 2000 Silverrado 2WD just started doing this tonight on my way home from work. It won't run above an idle, I got home and shut it off and had dinner. Went out after dinner and it fired up and ran normally until I got around the corner and had to stop at a stop sign. Went to take off from the stop sign and would only idle again. Any ideas, thanks in advance for any help with this.
Old Oct 30, 2009 | 4:29 AM
sewman's Avatar
Try changing your fuel filter.
Old Oct 30, 2009 | 11:02 AM
therewolf's Avatar
Your engine may be using your throttle cable as an auxiliary ground if your firewall/engine ground strap is too far gone.
In any event it seems like your throttle cable is slipping or stretched.
srmcnaughton@shaw.ca
Apr 23, 2013 2:59 PM
caroff
Apr 23, 2012 4:20 PM
gregvan2012
Dec 26, 2011 5:03 PM
giu
Nov 24, 2007 2:42 PM
ake11
Jun 29, 2007 1:36 PM
