2001 2500 4x4 6.0 engine swap
Old Mar 24, 2014 | 10:23 PM
jpy61660's Avatar
Default 2001 2500 4x4 6.0 engine swap
anyone know what year model 6.0 will work in a 2001. i've been told a 2005 will work, just change the intake. whats your thoughts
Old Mar 25, 2014 | 11:30 AM
cbarnett_2500's Avatar
Could you expound upon your OP please? Do you have a 6.0 in your 2001 now? Does it matter to you what year 6.0 it will be? Why do you want to do the swap?
Old Mar 26, 2014 | 11:15 PM
jpy61660's Avatar
mine is 01 6.0 339k miles, smokes and dropped a lifter. found a 05 6.0 time for a change.
Old Mar 27, 2014 | 9:17 PM
I see. To my knowledge, you can, in fact, put an 05 364 V8 into an 01. The frame brackets should be the same. I'm not entirely sure about the intake manifold though; if push comes to shove, you could transplant your old manifold into the new engine, therefore keeping the previous intake routing.
Old Mar 28, 2014 | 10:05 AM
Fishinfooleric10@aol.com's Avatar
The only difference is you have a cable throttle body and the 05 has an electric throttle body. All you have to do when changing motor out is swap intake manifold, throttle body, injectors with fuel rails. Everything bolts right up though. I don't know if you have an EGR but if you do once again no problem just keep your exhaust manifold and it swaps over too. Transmission and frame mounts are the same, oh my crankshaft sensor was different but I had to just swap that over. I have a 99 5.3 and put a 04 5.3.
screetcher
Mar 5, 2015 5:55 PM
Peter M
Oct 3, 2010 10:25 PM
stinemonster
May 30, 2009 1:43 AM
ias00
Oct 16, 2007 5:17 PM
huskersdomn8
Feb 22, 2007 11:23 AM
