2001 Chevy Silverado Diesel Starter, can't remove
I disconnected the starter and when I try to remove it, I can't get through the space between the manifold and frame. It also will not come out past the exhaust pipe and the frame. What is the best route to getting this out. Will I need to remove the entire exhaust pipe to get it out and put in the new starter?
6.5L & 6.6L Engines
To install:
- Remove or disconnect the following:
Negative battery cables
Right front wheel and fender splash shield, on 6.6L engines
Turbocharger exhaust pipe, on 6.6L engines
Mounting bolts/nuts and shim, if used
Starter
Wires
Heat shield and bracket
Fig. Exploded view of the starter motor-6.5L engine shown
To install:
- Install or connect the following:
Heat shield and bracket. Torque the bolts to 13 ft lbs. (17 Nm).
Wires. Torque battery wire nut to 89 inch lbs. (10 Nm), and ignition nut to 18 inch lbs. (2 Nm) on 6.5L engines. On 6.6L engines, tighten the solenoid nut to 30 inch lbs. (3.4 Nm) and the positive battery cable nut to 80 inch lbs. (9 Nm).
Starter
Mounting bolts/nuts and shim, if used. Torque the bolts to 33 ft lbs. (45 Nm) and the nut to 75 inch lbs. (8.5 Nm) for 6.5L engines. For 6.6L engines tighten the starter bolts to 58 ft. lbs. (78 Nm).
Right front fender splash shield and wheel, on 6.6L engines
freedomfighter_87
December 7th, 2009 7:32 PM
freedomfighter_87
December 3rd, 2009 6:30 PM
rossww
September 10th, 2009 10:21 PM
