2001 Chevy Silverado Diesel Starter, can't remove
Old Jun 20, 2010 | 9:45 PM
noemail9813's Avatar
Default 2001 Chevy Silverado Diesel Starter, can't remove
I disconnected the starter and when I try to remove it, I can't get through the space between the manifold and frame. It also will not come out past the exhaust pipe and the frame. What is the best route to getting this out. Will I need to remove the entire exhaust pipe to get it out and put in the new starter?
Old Jun 21, 2010 | 11:45 AM
cooter26's Avatar
6.5L & 6.6L Engines
  1. Remove or disconnect the following:
    Negative battery cables
    Right front wheel and fender splash shield, on 6.6L engines
    Turbocharger exhaust pipe, on 6.6L engines
    Mounting bolts/nuts and shim, if used
    Starter
    Wires
    Heat shield and bracket
    Fig. Exploded view of the starter motor-6.5L engine shown
To install:
  1. Install or connect the following:
    Heat shield and bracket. Torque the bolts to 13 ft lbs. (17 Nm).
    Wires. Torque battery wire nut to 89 inch lbs. (10 Nm), and ignition nut to 18 inch lbs. (2 Nm) on 6.5L engines. On 6.6L engines, tighten the solenoid nut to 30 inch lbs. (3.4 Nm) and the positive battery cable nut to 80 inch lbs. (9 Nm).
    Starter
    Mounting bolts/nuts and shim, if used. Torque the bolts to 33 ft lbs. (45 Nm) and the nut to 75 inch lbs. (8.5 Nm) for 6.5L engines. For 6.6L engines tighten the starter bolts to 58 ft. lbs. (78 Nm).
    Right front fender splash shield and wheel, on 6.6L engines
Old Jun 22, 2010 | 9:10 AM
Default Thank you
I thought that exhaust pipe was going to be a bear to take off. It worked like a champ and starter came right out. I appreciate your help!!
Marcus Worth
Cruze
Jul 31, 2013 2:31 PM
freedomfighter_87
Dec 7, 2009 7:32 PM
freedomfighter_87
Dec 3, 2009 6:30 PM
rossww
Sep 10, 2009 10:21 PM
rhaner
Jan 27, 2009 10:23 PM
