2001 HD, pinging, tapping
My nieghbor and I have been trying to figure out what the knocking and tapping is coming from the flywheel/torque converter area. Thought it was the motor for a long time. All bolts on flywheel are tight. Flywheel wobbles though, as you watch it when running. Knock is not all the time, but on most occasions it will sound off. Any problems with these? 6.0 liter, auto, 200,000 miles.
Professional Mechanic
It is possible that the flywheel is broken or cracked around the bolts holes (to the crank shaft) only way to be sure would be to pull the trans back. How much does it wobble? alot? or just slightly?
taderhold
January 31st, 2010 12:29 AM
acworthpatrick
January 27th, 2010 8:15 AM
ddc2001
July 7th, 2006 2:18 PM
