2001 silverado driverside leak
my driver side carpet has repeatedly become soaken wet mainly right along the plastic running board. ive looked over the seal along the door and even ran water to see if it drips or if i can even see where and from wince the water is coming from, i wanted to know if anyone else has had this problem and/or if whats the deal and how to come about a solution soon its starting to reeze out here and thats all i need is frozen carpet to add to my bucket of fun...
I had a similar problem (wet carpet beside drivers side pillar)which was diagnosed by local dealer to be an incorrectly hooked up drain hose for the sunroof.
you probably have typical sippage around the windshield seal, pillar A. you can pry weatherstripping off on the windshield, it is very easy to do even with a finger, or plastic spatula, and pack the gap you'll see with silicone sealant. or get a caulk gun, load silicone cartridge in, stick nozzle into that gap about 4 inches towards the midline, on the top pf the windshield, and fill that gap all the way down to the hood with sealant. shape of the nozzle itself will push weatherstrip away.
I have a 2001 Siverado with a soking wet passenger side when running the AC. I'm sure the drain is plugged. Does anyone know where it's located, and the most effective way to clean it out?
@willyb1, sounds like your heater coil is out. When those usually go out they start leaking. It is usually behind the glove box. No easy way to clean, pull the carpet far as you can, use a wet vac. it will start to smell moldy if not address quickly. Good luck.
k-beau mania
July 16th, 2014 1:06 PM
mackda600
September 14th, 2012 9:35 PM
Wolfpack45
January 8th, 2009 9:47 PM
drwalker88
February 12th, 2007 12:25 AM
