2001 silverado driverside leak
Old Nov 17, 2008 | 1:32 PM
IYAOYAS83's Avatar
Default 2001 silverado driverside leak
my driver side carpet has repeatedly become soaken wet mainly right along the plastic running board. ive looked over the seal along the door and even ran water to see if it drips or if i can even see where and from wince the water is coming from, i wanted to know if anyone else has had this problem and/or if whats the deal and how to come about a solution soon its starting to reeze out here and thats all i need is frozen carpet to add to my bucket of fun...
Old Nov 17, 2008 | 6:15 PM
thefishingguy's Avatar
Default RE: 2001 silverado driverside leak
I had a similar problem (wet carpet beside drivers side pillar)which was diagnosed by local dealer to be an incorrectly hooked up drain hose for the sunroof.
Old Nov 17, 2008 | 9:06 PM
ukrkoz's Avatar
you probably have typical sippage around the windshield seal, pillar A. you can pry weatherstripping off on the windshield, it is very easy to do even with a finger, or plastic spatula, and pack the gap you'll see with silicone sealant. or get a caulk gun, load silicone cartridge in, stick nozzle into that gap about 4 inches towards the midline, on the top pf the windshield, and fill that gap all the way down to the hood with sealant. shape of the nozzle itself will push weatherstrip away.
Old Jun 18, 2010 | 9:07 AM
willyb1's Avatar
Default 2001 Chevy Silverado passenenger side wet, suspect AC drain plugged
I have a 2001 Siverado with a soking wet passenger side when running the AC. I'm sure the drain is plugged. Does anyone know where it's located, and the most effective way to clean it out?
Old Jun 18, 2010 | 3:31 PM
juddkennedy's Avatar
@willyb1, sounds like your heater coil is out. When those usually go out they start leaking. It is usually behind the glove box. No easy way to clean, pull the carpet far as you can, use a wet vac. it will start to smell moldy if not address quickly. Good luck.
Old Jul 7, 2010 | 10:28 AM
cpbailey's Avatar
its also very common in these models to leak from the top of the back glass which after sitting in the rain can seep down into the carpet on the floorboard.
k-beau mania
Jul 16, 2014 1:06 PM
mackda600
Sep 14, 2012 9:35 PM
89silverado
Jun 11, 2009 8:57 AM
Wolfpack45
Jan 8, 2009 9:47 PM
drwalker88
Feb 12, 2007 12:25 AM
