2001 Silverado will not crank
Old Sep 22, 2010 | 7:57 AM
yagozotljb's Avatar
Default 2001 Silverado will not crank
I was having issues with what appear to be an itermitment clutch switch. I was able to get my truck starter by jumping the starter relay leds pin 30 -87 ( Ithink these are the correct pin number if I remember right) and turn the ignition key. While last time I started these two leads got stock together and it burnt my starter...no problem .. Got another starter,but now the truck will not even crank. I checked all fuses,the battery is new and fully charged and the new starter was bench tested. Any ideas how can I get this truck to crank again even if it is in a temporary basis?
Could the ignition switch got burnt as a result of these two wires beet stock together?
I was trying to find any wire diagram that can help ,but did not find anything here.
338mag
Dec 11, 2023 7:27 AM
malique93
Jun 24, 2014 10:41 PM
summit800
Jul 22, 2013 7:57 PM
Doug M
Apr 17, 2012 9:56 PM
hondalover
Feb 1, 2011 4:06 PM
