2002 Silverado Vehicle Speed Sensor Problem
Old May 19, 2014 | 7:18 PM
bass1's Avatar
Angry 2002 Silverado Vehicle Speed Sensor Problem
While driving the transmission started jumbing in and out of gear as well as the ABS light and red brake light came on. Had it scanned and it said it was the Vehicle Speed Sensor on the transmission. I changed the sensor and reset the lights. It seemed to fix the problem for about a week and then did it again. I replaced the sensor again and it seems to have fixed it. I was wondering what could be causing the sensor to be going bad or if there may be another issue all together.
Old May 24, 2014 | 5:44 PM
bass1's Avatar
testone
Old May 24, 2014 | 8:03 PM
if the problem doesn't return you got a bad part...aftermarket or oem part?
if it does return, you may have an intermittent wiring problem. post the dtc that sets if it does return
Old May 25, 2014 | 6:21 AM
Allan In NE's Avatar
What Tech2 said,
The only other thing is that the reluctor ring could be split and slipping on the shaft.
Allan
MegaMiles
Apr 27, 2026 2:08 AM
osqari
Cruze
Apr 30, 2016 8:50 PM
TipTricky
Dec 13, 2013 5:58 PM
kamal
May 27, 2012 1:05 AM
cdubya
Oct 6, 2010 5:55 AM
