2003 Silverado with Heater Problems.. only works after I go 60mph
Old Jan 6, 2009 | 5:39 PM
sbasmiles's Avatar
Default 2003 Silverado with Heater Problems.. only works after I go 60mph
It's the strangest thing; down in Houston luckily we don't need to use our heat that often, but when it's cold it's COLD! Anyhow my heater only seems to work after I go 60 mph, and will stop working if I slow down. In rush hour traffic, it will not work at all. I have notices the temp. gauge is reading higher (but not in the red) than normal.
I've had my A/C panel replaced twice already for problems on the dial in the middle. I really don't want to go back to the dealer for them to replace this panel again! Could it be something simple a local mechanic or myself can fix?
Any tips would be great.. my truck is almost paid off & looking forward to keeping it another 100K!
Thanks
Old Jan 6, 2009 | 8:23 PM
shawnvw's Avatar
Banned
Default RE: 2003 Silverado with Heater Problems.. only works after I go 60mph
Does the blower motor stop sorking? or do you just lose your heat? If its the latter, it could be thermostat, a partially plugged heater core, or simply low coolant
Old Jan 7, 2009 | 2:03 AM
bubba33's Avatar
My impala did that when it was a bit low of coolant.
tinytec
Sep 2, 2019 12:19 AM
joshkruger
11
May 23, 2008 12:25 PM
dylskee
May 12, 2008 12:39 AM
brenande
Jan 27, 2008 12:40 AM
02Lightning
Nov 23, 2006 1:21 PM
