Old Aug 10, 2015, 1:53 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Lighting Guides
Print Wikipost
2004 silverado left brake light not working
Old Jul 14, 2011 | 6:19 PM
laxshot11's Avatar
Default 2004 silverado left brake light not working
ive checked the bulbs and changed them, any ideas on which fuses to check or if there are other possible problems the right light still works and all of the left except the brake. HELP
Old Jul 15, 2011 | 12:31 PM
slw210's Avatar
So you are saying your left flasher works? Did you use new bulbs? Sounds like a wire or the connector. I am no expert at troubleshooting over network, so I hope I am being helpful. Let me know all you have tried. I would get out the multimeter and start wiggling wires.
Old Jul 15, 2011 | 2:58 PM
GM Fixer's Avatar
Down under tailgate, there is a MULTI-CONNECTOR remove and inspect terminals and yes make sure you use new blubs and correct part number
Old Jul 16, 2011 | 8:46 AM
skeeter5's Avatar
The brake lights are wired through the signal light switch. I don't know up to date details, but this switch could be the problem.
Old Jul 19, 2011 | 1:56 PM
StrictlyChevy's Avatar
Do you have cruise control? Does it work sometimes and not? If so it could be the brake light switch. The cruise control is tied in with it so it ia one way that could help determine if that is the problem. Even if not it could still be the Switch that needs replacing.
Old Sep 8, 2011 | 10:01 PM
frustratedinKS's Avatar
I seem to be having the same issue only more severe. It seems that the brake light works intermittently when I turn the turn signal on but I found that the turn signal stays lit on both the front and rear when I step on the brakes. It was only the left side but it seems as though it may be more. I was trying to figure it out and when I had the turn signal on that all the brake lights would flash like the hazards. I have been unable to reproduce that after several more attempts. I have checked all the fuses and the bulbs are good. It looks as though there may be some missing fuse or switch (large plug with no connector) in the fusebox inside the drivers door.
Old Sep 10, 2011 | 9:24 AM
I tried replaceing the turn signal switch and the brake switch but still have the same problems.
Old Sep 10, 2011 | 10:15 PM
OLD WRENCH's Avatar
Do these have the circuit board in the tail light assy that give a lot of trouble?
Old Sep 11, 2011 | 9:42 PM
Fixed it. Apparently the hazard relay box was bad. It is located behind the Driver door Fuze box. I took off the panel to get to it. Good luck.
Old Sep 12, 2011 | 11:30 AM
skeeter5's Avatar
Glad you were able to take care of it.
Good information.
Thanks for posting this fix.
TruckManDan
Dec 25, 2014 7:52 AM
ericconn
Jun 19, 2012 9:56 AM
RomanGuzi
Oct 2, 2011 11:40 AM
1LooseLugNut
Aug 15, 2010 6:46 PM
derekf
Apr 24, 2009 9:57 PM
