2007 Silverado 4.8L - Engine Noise
Old Mar 7, 2010 | 3:44 PM
brien s's Avatar
Default 2007 Silverado 4.8L - Engine Noise
Recently heard a squeak/clicking sound; isolated it to first cylinder rocker arm. Replaced rocker arm, noise went away for 4 days, then reappeared. Replaced rocker arm again, noise persists.
Any ideas?
-Thanks
Old Mar 7, 2010 | 5:25 PM
ristpin's Avatar
Did you adjust it properly? Too tight and no oil will pump thru the push rod from the lifter to lube the rocker!!! Did you lube it good when you installed it? If it's "squeaking", it sounds like no oil!!!!
Old Mar 7, 2010 | 6:31 PM
maxxman04's Avatar
if not rocker arm, probably lifter.
teddyramey86
Aug 25, 2015 5:34 AM
jcolo052
Jul 10, 2014 8:23 PM
Melody Smith Arquillo
Dec 3, 2012 12:48 PM
Chevy_07
Oct 9, 2012 8:09 AM
perfer chevy
Feb 18, 2008 4:18 PM
