2008 Chevy Silverado 4.8L V8 Low oil pump pressure.
Old Jan 1, 2014 | 5:21 PM
Sul303's Avatar
Default 2008 Chevy Silverado 4.8L V8 Low oil pump pressure.
I need to replace the oil pump on my 08 Silverado for that i will need to drop the oil pan, but does anyone know if am required to lift the engine??? fast answers will be appreciated. thanx
Old Jan 1, 2014 | 6:58 PM
That really is an uncommon problem.
did you verify the pump was bad or are you basing this on what the gauge reads?
Old Jan 1, 2014 | 7:31 PM
Allan In NE's Avatar
What makes you think you need to replace the oil pump?
Allan
Old Jan 2, 2014 | 10:33 PM
Sul303's Avatar
Allan
Besides my gauge is not reading any pressure whatsoever, the low oil pressure light came on and stop engine light came on as well. Then its making a taping noise. What do you suggest it could be? could it just be the oil sensor ? any suggestions are welcome and thank you in advance.
Old Jan 2, 2014 | 10:35 PM
Sul303's Avatar
Old Jan 2, 2014 | 11:06 PM
the first step would be to check the oil level.
if its not low, the next step would be to verify the oil pressure at idle and 2500rpm at the filter and oil pressure sensor with a master gauge.
usernamehere
Aug 2, 2021 12:07 PM
Eric Sherden
Sep 24, 2013 1:21 PM
not_a_car_dude
Sep 15, 2013 7:41 PM
MikeShirk
Dec 31, 2012 10:39 AM
Dallas4
Oct 23, 2012 1:45 PM
