2008 Silverado Navigation added, need advice
I have a 08 Silverado LTZ that came with the 6 disc in dash radio, I recently added a nav system out of a 08 suburban, i had the radio unlocked at my dealership and have it hooked up and working, but i think something is missing, the radio and steering wheel controls all work, the map works and xm works, but when you enter a destination it will tell you to begin but it doesn't tell you anymore turns to make until you reach your destination and it tells you that you have arrived, also while you have a address entered, there is a big compass on the right side of the screen that i can not get rid of, map left and compass on right. The map is full screen if it is just in map mode. I only had 2 plugs on back of radio, and one for antenna and 1 for gps antenna.
Please Help,
Please Help,
hey i have not herd yet of a radio with only 2 plugs on the back, that is weird, what if you want back up camara, or what about the vss wire and everything else? where do you plug those?
but most likely the tech didn't program your radio the way is suppossed to, i would go back and ask them if they really know what they are doing! but you know what the answer is going to be.
i installed the navi in my '07 silverado and so far so good, only i'm missing the gps antena so if anyone have an extra one let me know.
hey, just enter navigation in the search box and you will get a lot of info about it, i got a navi unit from a cadillac and installed it on a '07 silverado w/o bose and it works just fine
I have searched for more information and found how to program it with the Tech II system. I brought my truck to the dealer, and the tech said that they use an MDI system to program. Every time they try to unlock the hu, He said that it says "connection failed, check connection and retry." I have removed the system several times and it still has that issue. Am I missing something? Does the tech have to use the Tech II system to relearn my vin (using an 06 Monte Carlo)?
adamant
June 25th, 2021 5:07 PM
NKYCarGuy
March 6th, 2007 7:10 PM
zoey
October 11th, 2006 2:51 PM
