2008 Silverado Navigation added, need advice
Old Dec 22, 2009 | 5:10 PM
selbo's Avatar
Default 2008 Silverado Navigation added, need advice
I have a 08 Silverado LTZ that came with the 6 disc in dash radio, I recently added a nav system out of a 08 suburban, i had the radio unlocked at my dealership and have it hooked up and working, but i think something is missing, the radio and steering wheel controls all work, the map works and xm works, but when you enter a destination it will tell you to begin but it doesn't tell you anymore turns to make until you reach your destination and it tells you that you have arrived, also while you have a address entered, there is a big compass on the right side of the screen that i can not get rid of, map left and compass on right. The map is full screen if it is just in map mode. I only had 2 plugs on back of radio, and one for antenna and 1 for gps antenna.
Please Help,
Old Dec 22, 2009 | 6:01 PM
QUETRANPA's Avatar
hey i have not herd yet of a radio with only 2 plugs on the back, that is weird, what if you want back up camara, or what about the vss wire and everything else? where do you plug those?
but most likely the tech didn't program your radio the way is suppossed to, i would go back and ask them if they really know what they are doing! but you know what the answer is going to be.
i installed the navi in my '07 silverado and so far so good, only i'm missing the gps antena so if anyone have an extra one let me know.
Old Dec 22, 2009 | 9:27 PM
shawnvw's Avatar
Banned
did you follow the instructions as outlined in the HOW TO from the tahoe suburban section?
sounds like a few wires were missed during the install
Old Jan 1, 2010 | 11:49 AM
selbo's Avatar
there was only 2 plugs that plugged into the radio, and then it had a blue plug for gps antenna and another plug for radio antenna
Old Jan 4, 2010 | 6:21 PM
shawnvw's Avatar
Banned
You need to install the VSS wire at the radio. Read the HOW TO on where to find the wiring
Old Mar 25, 2010 | 8:59 PM
DesertSierra's Avatar
I have a 07 Sierra Sle without bose and purchase a nav unit out of a 07 denali (which I think is the lux version). How can I make this work in my truck?
Old Mar 26, 2010 | 10:41 PM
QUETRANPA's Avatar
hey, just enter navigation in the search box and you will get a lot of info about it, i got a navi unit from a cadillac and installed it on a '07 silverado w/o bose and it works just fine
Old Mar 27, 2010 | 11:45 AM
I have searched for more information and found how to program it with the Tech II system. I brought my truck to the dealer, and the tech said that they use an MDI system to program. Every time they try to unlock the hu, He said that it says "connection failed, check connection and retry." I have removed the system several times and it still has that issue. Am I missing something? Does the tech have to use the Tech II system to relearn my vin (using an 06 Monte Carlo)?
Old Mar 30, 2010 | 7:48 PM
shawnvw's Avatar
Banned
desertsierra.....absolutely!
the MDI will not work using this method
adamant
Jun 25, 2021 5:07 PM
cocodrie55
Jan 24, 2008 10:35 PM
NKYCarGuy
Mar 6, 2007 7:10 PM
zoey
Oct 11, 2006 2:51 PM
