2010 2500 - Silverado - Rattling upon excelleration and at speeds over 75
Old Aug 23, 2012 | 10:49 AM
gmhigbee's Avatar
Default 2010 2500 - Silverado - Rattling upon excelleration and at speeds over 75
I am experiencing a rattling that appears to be coming from the passenger side of the enging that only happens when hard excelleration 0-50 and at speeds over 75. I have changed the belt tensioners as well as checked the fan shroud. Any ideas of other things that could be causing the rattle?
Old Aug 27, 2012 | 1:36 AM
jesse06's Avatar
motor mount? heat sheild on the manifolds, bad tire... or does it sound like its coming from in the engine?
Old Aug 27, 2012 | 3:24 PM
gmhigbee's Avatar
Definetly from the engine. Motor mount has been fixed as well. Will consider heat sheiled on manifolds. New tires so that is out.
Old Aug 28, 2012 | 12:41 PM
Official GM Rep
<!--[if gte mso 9]><xml> <w:WordDocument> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:PunctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <wontGrowAutofit/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> </w:WordDocument> </xml><![endif]--><!--[if gte mso 9]><xml> <w:LatentStyles DefLockedState="false" LatentStyleCount="156"> </w:LatentStyles> </xml><![endif]--><!--[if gte mso 10]> <style> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} </style> <![endif]--> gmhigbee,
Have you been able to resolve this issue? The vehicle is still under warranty correct?
Louis
GM Customer Service
Old Aug 29, 2012 | 9:47 AM
gmhigbee's Avatar
Not resolved yet and no the vehicle is not covered under any warranty
Old Sep 4, 2012 | 1:09 PM
Official GM Rep
I have researched my resources and there are currently no known issues, based on your description. I encourage you to consult with a certified technician for an inspection. They should be able to offer additional information after inspecting the vehicle.
Please keep us posted.
Louis
GM Customer Service
thisnthat
Nov 20, 2012 11:36 AM
sirguinness
Uplander
Nov 11, 2011 8:58 AM
ajrkar
Jul 18, 2011 10:33 AM
93HEAVY(BUBBLE)
May 12, 2011 5:00 AM
