Notices
Old July 29th, 2015, 2:14 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Wheels and Tires
Print Wikipost
2011 Silverado Vibration = Rough Ride.
Old January 27th, 2012, 8:23 AM
  #21
woodrow's Avatar
Originally Posted by AaronIROCZ
I just purchased my 2012 on the 21st and I have yet to notice any vibrations although mine is a crew cab and I see the original posters is an extended cab. I have yet to see anyone ask if the driveshaft has had the balance checked out yet??
Mine is a crew and I do have the vibration problem. What is the first number in your VIN?
Old January 27th, 2012, 8:29 AM
  #22
pearl's Avatar
Imentioned the d/s but the enginers mantain it is in the tires and have that thought stuck in their minds. I have been told its only in the extened cab. I dont want a truck like this at half the price. Although a crew cab has been brought up as a repair. Also did the other truck have the bigger motor aqnd the 6 speed trans. Good luck on monday please keep me posted
Old January 27th, 2012, 8:52 AM
  #23
chevy2011vibration's Avatar
Default Update. Try replacing steering column.
I would suggest to all that you have your dealer check and replace the steering column in your truck.
After taking my truck to two dealerships, the second dealership actually spent some time trying to figure out what was causing the vibration (going beyond the usual tire / balance excuse). They found lots of "play" in the steering column and decided to just replace the entire part.
Although my truck still doesn't ride as nice as my 2008 did, replacing the steering column has helped. I no longer notice vibration on the highway and it is less noticable at slower speeds.
Hope this helps other frustrated owners. I also hope that GM does something to correct this in the future... so make sure you open a case with GM and report back to them what needed to be fixed.
Old January 27th, 2012, 9:35 AM
  #24
mcox8051's Avatar
First number? My VIN is 1GCRKSE30BZ432621.
Old January 27th, 2012, 12:00 PM
  #25
AaronIROCZ's Avatar
3, mine is a 6.2L non Z71 and 20" factory chrome clad wheels and 4X4 1500.
Old January 27th, 2012, 12:53 PM
  #26
louann11chevy's Avatar
Everyone - If you have a truck with a vibration problem what is the first number in the VIN number. I am finding locally that the trucks that ride smooth do not start with the same number as mine does. Mine start with 3.
sorry to feel your pain, i just bought a '11 couple months ago crew cab tho with only a couple thousand miles on it. No vibration so far (knock on wood), but my vin# begins with a 3 also.
Old January 27th, 2012, 1:21 PM
  #27
mcox8051's Avatar
Want to clarify. Are we calling the 6th digit from last the first number? If so, mine is a 4 and it vibrates.
Old January 28th, 2012, 4:15 PM
  #28
Bobby2011lt's Avatar
Default tire pressure low light
i have a 2011 1500 lt and it say my front right tire low i checked it and all my other tire r set to 35 psi it wont go off any way to rest it ??
Old January 29th, 2012, 7:29 PM
  #29
pearl's Avatar
my number is also a 3 What does that mean the 3.
Old January 30th, 2012, 7:14 AM
  #30
woodrow's Avatar
Chevy2011vibration - do you have the part numbers on your reciept for the parts they replaced?
Quick Reply: 2011 Silverado Vibration = Rough Ride.
