2012 silverado 1500
2012 silverado 1500
I have a slow cranking issue. Its starts good. Acts like battery is low but its checks out good.
Also looking how to disable ignitions so I can crank starter without it actually starting.
pull the fuse for the fuel pump or fuel pump control module. start it and let run until it stalls. then you can do a starter draw test. make sure your battery is fully charged. the more discharged the battery is; the higher the amp draw.
mmenefee
2007 - 2013 (GMT900)
January 14th, 2019 11:49 AM
codecop
October 4th, 2018 6:51 PM
