2012 silverado 1500
Old Oct 23, 2020 | 12:09 PM
E&D's Avatar
E&D
Default 2012 silverado 1500
I have a slow cranking issue. Its starts good. Acts like battery is low but its checks out good.
Also looking how to disable ignitions so I can crank starter without it actually starting.
Old Oct 24, 2020 | 4:56 AM
oilcanhenry's Avatar
Are you looking to make a kill-switch for security purposes?
Old Oct 24, 2020 | 7:09 AM
pull the fuse for the fuel pump or fuel pump control module. start it and let run until it stalls. then you can do a starter draw test. make sure your battery is fully charged. the more discharged the battery is; the higher the amp draw.
Old Oct 24, 2020 | 8:22 AM
E&D's Avatar
E&D
No, Just trying to check starter amp draw.
Thanks for responding.
Old Oct 24, 2020 | 8:23 AM
E&D's Avatar
E&D
Thanks for the response
Old Oct 27, 2020 | 12:03 PM
E&D's Avatar
E&D
Turns out to be starter for slow cranking. Replaced and cranking is great.
Old Oct 29, 2020 | 9:03 AM
That always good to hear. Many a good battery has been replaced when it was the starter.
lukealan818
2007 - 2013 (GMT900)
Jan 26, 2020 7:53 PM
mmenefee
Jan 14, 2019 11:49 AM
Jhendricks
Oct 14, 2018 10:44 PM
codecop
Oct 4, 2018 6:51 PM
johnvosh
Cobalt
Jan 1, 2012 3:04 PM
