2500 HD Duramax 2011 Shocks???
Old May 12, 2014 | 10:04 PM
mastercraftka's Avatar
Default 2500 HD Duramax 2011 Shocks???
I know I have a heavy truck with heave tires but the back end just shakes and vibrates. My console cup holder just shimmys!! I just put new tires on the back I am thinking about replacing the shocks next. The PO put 30k on it and I have 71k now. If I replace the shocks what should I put on?
Old May 13, 2014 | 6:09 PM
country_09's Avatar
Bilstein 5100s are a nice option
Old May 14, 2014 | 12:00 AM
Pugly's Avatar
Doesn't sound like a shock problem - I'd have the tire balance rechecked.
How does the drive shaft and u-joints look?
Factory shocks are usually cheap shocks - almost anything will be an improvement.
Old May 14, 2014 | 8:36 AM
I am pretty sure that the new tires are not the problem did this before the new tire as well.
I did check the u joints some time ago but I do need to check them again I am glad you reminded me.
I think I might replace the rear shocks either way like you said the stock shocks are cheap.
Old May 15, 2014 | 8:36 AM
I ordered bilstein rear shocks yesterday, when they come in I will check the driveshaft too.
Old May 15, 2014 | 10:33 AM
Pugly's Avatar
let us know if this fixes your vibration problem
Old May 15, 2014 | 4:26 PM
country_09's Avatar
You happen to have aftermarket wheels on the truck?
Old May 16, 2014 | 8:02 AM
No rims are stock 18"
Old May 20, 2014 | 10:42 PM
gearbox's Avatar
Would like to hear the improvement with bilstein shock and if it solve the problem.
Old May 21, 2014 | 8:25 AM
Ok just got them on last night. I checked the drive shaft and u joints too and they are tight.
I will have to say that it was not a night and day difference but I can tell that it helped. Mainly when I hit a bump it recovers faster and doesn't linger. I still have a shimmy not as bad when going down the highway at 70mph.
I was told to try the hard surface balance I might try to do that as well sometime soon. I will probably just go ahead and order some for the front next, those are probably in worse shape being on the heavy end of that duramax and a front replacement bumper.
ak_
Mar 31, 2013 11:01 PM
Sambor
Jul 18, 2011 8:34 AM
sjlewis
Jun 17, 2011 11:37 PM
Chevymax
Nov 26, 2010 9:43 PM
nielsen1426
May 3, 2010 11:05 PM
