2500 HD park Brake Problems
Old Mar 26, 2008 | 8:13 PM
Phil Speadahead's Avatar
Default 2500 HD park Brake Problems
Hi all, newbie here. Just about through a brake job on my 2001 2500 HD. Got three wheels done without too much grief. On the last one and the darn drum will not come off. I have slacked off the adjuster rod inside the drum,(at least it is loose when viewed through the small access hole) and still the drum will not come off. Thinking that the park brake cable is still under tension but cannot figure out haw to slacken it off. I have a manual that shows the park brake cable with a nut and bolt slack adjuster half way back , but on the truck there is no such monster. Where do you slacken the park brake cable ? At the pedal ? Also if I cannot free up the brake shoes on the park brake any suggestions on getting the drum off ? The disks have worn the rotor side down to mins so I was replacing the drum/rotors any way so I have hammered the back of the rotor/drum pretty seriously with no movement.
Hope there is someone out there familiar with this problem
Thanks a bunch.
Old Mar 26, 2008 | 9:07 PM
northey87's Avatar
Default RE: 2500 HD park Brake Problems
Welcome to the forum!!! Some one should be able to help, just hang in there.
RIGGS123
Jul 9, 2014 5:29 PM
jrobpush
Mar 22, 2013 10:37 AM
keeferster
May 29, 2011 10:53 PM
seanw
Feb 18, 2010 5:58 PM
ubique
Mar 25, 2008 3:31 PM
Top
Follow Us
