283 sbc
I am wanting to know if you can use a regular hyd cam and lifters with comp lifters?The cam and lifters is a little above stock. And if not can i take the lifters off without any problems.And replace them without any problems?thanks
![Confused](https://chevroletforum.com/forum/images/smilies/confused.gif)
i take it that your cam and lifters you have now are a mild hydraluic set ? you run matching lifter's with the cam as a set .if the set has been run ,you do not want to change them because there has been a wear pattern established .
you should only replace as a set because it could wipe out the cam .
