283 sbc
Old Jun 7, 2010 | 5:15 PM
djgj74's Avatar
Default 283 sbc
I am wanting to know if you can use a regular hyd cam and lifters with comp lifters?The cam and lifters is a little above stock. And if not can i take the lifters off without any problems.And replace them without any problems?thanks
Old Jun 7, 2010 | 10:00 PM
old dog's Avatar
Default ?
i take it that your cam and lifters you have now are a mild hydraluic set ? you run matching lifter's with the cam as a set .if the set has been run ,you do not want to change them because there has been a wear pattern established .
you should only replace as a set because it could wipe out the cam .
Old Jun 9, 2010 | 6:02 PM
djgj74's Avatar
what i meant was can i use rocker rollers with hyd. cam and lifters with no problems?
Old Jun 9, 2010 | 6:05 PM
maxxman04's Avatar
yes, roller tip rockers are made and can be used. specify that you are using hydraulic non roller cam, you just want roller tip rockers to use.
Old Jun 9, 2010 | 8:03 PM
djgj74's Avatar
well my problem seems to be that it wont set and idle, it did for acouple of days and now it wont any ideas thanks.
cukali
Jul 16, 2011 7:14 PM
badintentionz
Dec 17, 2006 4:12 AM
