3"-4" suspension lift without blocks
Old Dec 20, 2010 | 4:36 PM
GMJack38's Avatar
Default 3"-4" suspension lift without blocks
The title pretty much says what im lookin for. I'm looking to put a 3"-4" suspesion lift on my 2003 Silverado 1500 Z71. The problem i'm running into is that I don't want to use blocks, AT ALL, and all the kits i find have blocks for the rear. I'm thinkin i may have to piece one together but i'm lookin to see if there is a kit first. If you know of a specific brand that i can go through to piece it together or a full kit then it would be most appreciated.
Old Dec 20, 2010 | 10:43 PM
country_09's Avatar
rancho has a good line of 4 in suspension lifts on 4wheelparts.com but they all include blocks so you might do what I want to do to, which is order the superlift 2-3.5 inch lift system. basically it's a 2 inch front lift system and you adjust the rest of the way with the torsion keys to how ever high you want. and for the back just order a add-a-leaf pack and you're set. but if you want the 4 inch system just see if you can substitute the blocks with add-a-leafs instead
Old Dec 21, 2010 | 7:24 AM
GMJack38's Avatar
Aight man i'll probably try the lift with and use add a leaf. Thanks
Old Jan 1, 2011 | 12:28 PM
CJ_Tiz's Avatar
I couldn't find anything myself I had to go with a 4" RCD lift. But again it uses blocks in the rear. You could do something like a bastard pack for the rear springs. I know alot of jeep owners running bastard packs.
ChevyJo
May 3, 2014 4:06 AM
CptDondo
May 5, 2012 6:26 PM
Rlock4227
Feb 19, 2012 11:26 AM
Droptine
Dec 2, 2011 5:00 PM
tmcelveen1985
Aug 28, 2009 11:33 AM
