305 to 350 swap
305 to 350 swap
I have a 97 Sierra K1500, it currently has a 305 but its pretty weak. Has anybody been involved in a 305 to 350 swap or know a good link? I would probobly swap out the trans too, the truck was used for towing so its pretty weak. Any info would be greatly appriciated.
305 to 350 is a straight across swap. same block, trans bolt pattern, everything. the only difference is the internals of the engine, which doesn't affect it bolting in at all.
If its a automatic, I would keep the 700 tranny. It has a lower 1st gear. It will get you out of the hole quicker, and will give you better gas mileage with the overdrive.
Rockhugger
October 27th, 2019 2:05 AM
