305 to 350 swap
Old Mar 1, 2010 | 3:30 PM
enrico_2006's Avatar
Default 305 to 350 swap
I have a 97 Sierra K1500, it currently has a 305 but its pretty weak. Has anybody been involved in a 305 to 350 swap or know a good link? I would probobly swap out the trans too, the truck was used for towing so its pretty weak. Any info would be greatly appriciated.
Old Mar 3, 2010 | 2:52 PM
Phil M's Avatar
You shouldn't have any problems, same block.
Old Mar 3, 2010 | 4:08 PM
therewolf's Avatar
Hi enrico_2006 and Phil M,
Welcome to the Chevy Forums.
There's a lot of stuff out there that should fit. You just have to look around.
Old Mar 3, 2010 | 4:09 PM
maxxman04's Avatar
305 to 350 is a straight across swap. same block, trans bolt pattern, everything. the only difference is the internals of the engine, which doesn't affect it bolting in at all.
Old Mar 3, 2010 | 8:39 PM
MDTAHOE's Avatar
Professional Mechanic
Take the 305 out and put the 350 in and you are done. The computer will take care of the rest.
Old Mar 4, 2010 | 5:33 AM
Phil M's Avatar
Thank you sir!
If its a automatic, I would keep the 700 tranny. It has a lower 1st gear. It will get you out of the hole quicker, and will give you better gas mileage with the overdrive.
Old Mar 4, 2010 | 11:22 AM
Do I have to swap the computer?
Old Mar 4, 2010 | 1:31 PM
maxxman04's Avatar
no. entire harness, computer all that is the same. the intake system and exhaust are the same as well.
Rockhugger
Oct 27, 2019 2:05 AM
jaymoung
Dec 18, 2011 9:12 PM
norcalrider
Nov 15, 2008 12:45 AM
sally
Jul 29, 2008 7:38 AM
