383 stroker help! 2000 silverado
Old Apr 14, 2007 | 2:13 PM
xx76scorpsxx's Avatar
Default 383 stroker help! 2000 silverado
hello, i have a 2000 chevy silverado ext cab z71 with a 5.3 vortec. my dad is a machinest and highly qualified mechanic. we want to swap my 5.3 for a 5.7 and stroke it to a 383 stroker. what i want to know is what complications will we cross? i relize the intake wont fit but what else will i need to change or swap such as computer, tbi, exhaust, motor mounts, intake manifold, exhaust manifolds, all the componants like ac, alternator, power steering pump etc .or would u have the specs or a recomendation to build up the 5.3 or a stroker kit for it? any information is highly apreciated thanks
Old Apr 14, 2007 | 5:13 PM
RonH's Avatar
Default RE: 383 stroker help! 2000 silverado
I think you should ask a highly qualified mechanic.
Old Apr 14, 2007 | 8:49 PM
kcb37's Avatar
Unless things have changed in the last few years all the externals should be a direct bolt on. If you can get a complete 5.7 form air cleaner to cats, and computer that would make it easier though. Your engine mounts and radiator and hoses should work fine. If you do find a 5.7 and decide to put that in Summit racing has a 383 stroker kit for the vortec engines. It cost around 1000 dollars.
Their # is 1-800-230-3030
Good luck
Old Mar 5, 2012 | 9:36 PM
BullyDawg's Avatar
just build up your 5.3 liter. it will be better in the long run because you wont have to worry about having to do any rewiring to the harness.
Old Mar 5, 2012 | 10:24 PM
Exhausted's Avatar
You won't have to re wire anything!
All external parts bolt up
But a 383 is kind of a waste because of all the extra parts
I would look into a 6.0L block and stroke it to a 402ci
Then use L92 heads and L76 intake and bam
Good to go
Or look into a 370ci
Old May 11, 2014 | 1:17 PM
Matthimmelspeck's Avatar
New User
Awaiting E-mail Confirmation
Good to go
I would not use a stock 6.0L block if your wanting to put some serious hp on it cause a stock engine block from gm is only rated up to 450hp before stuff starts blowing through block
"Speaking from experience"
If I were you I would spend the extra money and and get a reinforced race block and start from there and build it up
Old Jan 27, 2016 | 9:53 PM
Jovi neathery's Avatar
Default How do you build a 5.3 to match the HP of a 383?
What all do you need to build a 5.3 to a 383?
adairfuentes
Oct 18, 2014 4:04 PM
0midnight5
Aug 23, 2012 1:23 PM
SkIdude
Jan 5, 2012 12:36 PM
chevykicksbut
Oct 13, 2010 4:12 PM
311jman
Aug 22, 2010 10:10 PM
